Posted: Wed Jan 27, 2021 11:21 am Post subject: |
I've also used Odyssey batteries , they are GREAT for starting and duration , however they are VERY HEAVY !!! |
polyesterpig
Posted: Sat Mar 20, 2021 12:40 am Post subject: |
Does the Odyssey battery really weigh 15.5 lbs (7.0 kg)? _________________ 2002 Cannondale E440
(3) 2003 Cannondale E440R
2000 Bimota DB4ie BiPosto |
Posted: Tue Mar 23, 2021 10:59 am Post subject: |
polyesterpig wrote: |
Does the Odyssey battery really weigh 15.5 lbs (7.0 kg)? |
They are HEAVY , although from memory they do 2 variants of each model . One variant is steel reinforced for crash performance so even HEAVIER |
LucasJ
Posted: Sat May 08, 2021 4:03 am Post subject: |
Alright fellas, winter has finally come to an end. Spent a few hours steam cleaning and getting the bike ready for a test run. Turns over and sounds healthy. Just need some fresh plugs and oil and we’ll be good to hear it fire! Running dummy 1098 stock pipes for now, just to have something in place.
Jaguar
Posted: Sat May 08, 2021 1:54 pm Post subject: |
How do the 1098 pipes fit? _________________ Bimota (Tesi 1D 904SR, DB2, DB4, SB6,SB6R, SB8R, SB8K Santa Monica) Ducati (1000SS, Monster S4, 999R) Aprilia (RSV Mille R Haga) Honda (CL125s and 70s Chopper) |
LucasJ
Posted: Sat May 08, 2021 3:58 pm Post subject: |
Jaguar wrote: |
How do the 1098 pipes fit? |
The stock 1098 pipes are the same diameter but are not angled perfectly so with some slight pipe bending, I think they would work well. I have yet to fit them with the tail section, so I’ll report back when I get to it. The cans are a good fit, the contoured pipe leading to the can is a bit off.
I am a fan of the TwoBrothers carbon pipes on Japanese twins - the V.A.L.E. System has the exhaust cans detached from the entry pipe and allows for a significant amount of adjustment. That is my current plan moving forward. |
Jaguar
Posted: Sun May 09, 2021 11:50 pm Post subject: |
You peaked my interest.
My SB8K SM has the OEM cans for now. _________________ Bimota (Tesi 1D 904SR, DB2, DB4, SB6,SB6R, SB8R, SB8K Santa Monica) Ducati (1000SS, Monster S4, 999R) Aprilia (RSV Mille R Haga) Honda (CL125s and 70s Chopper) |
LucasJ
Posted: Sun May 23, 2021 4:11 am Post subject: |
It’s alive!
[url] https://m.youtube.com/watch?v=cWRsLxVi0PE[/url]
Idles and runs great so far.
Fuel tank is leaky at the separation seam. Will need to fix before test ride, so it’ll be a bit I’m sure.
Next steps:
Fuel tank repair
Exhaust fabrication
Seat fabrication. Thinking of 3D printing a base for now. Let me know if anyone has a better idea
Can’t sleep. This thing kicks ass |
Jaguar
Posted: Sun May 23, 2021 12:57 pm Post subject: |
If you need help with the carbon, reach out to Matt.
http://www.tannermatic.com/
He can sort almost anything. _________________ Bimota (Tesi 1D 904SR, DB2, DB4, SB6,SB6R, SB8R, SB8K Santa Monica) Ducati (1000SS, Monster S4, 999R) Aprilia (RSV Mille R Haga) Honda (CL125s and 70s Chopper) |
LucasJ
Posted: Mon May 24, 2021 5:13 pm Post subject: |
Thanks for the referral, Jaguar. I’ll have to give him a call and see what he thinks. Looks like a really experienced guy. Greatly appreciated |
Jaguar
Posted: Mon May 24, 2021 8:27 pm Post subject: |
LucasJ wrote: |
He is legit.
Local racing legend too. _________________ Bimota (Tesi 1D 904SR, DB2, DB4, SB6,SB6R, SB8R, SB8K Santa Monica) Ducati (1000SS, Monster S4, 999R) Aprilia (RSV Mille R Haga) Honda (CL125s and 70s Chopper) |
LucasJ
Posted: Tue Jun 01, 2021 7:14 pm Post subject: |
[/img][/url]
Quick snapshot. Coming along nicely |
LucasJ
Posted: Sun Jun 27, 2021 5:52 pm Post subject: |
Can’t resist a good shot. Still some work left but it’s coming along nicely |
Posted: Wed Jul 14, 2021 12:53 pm Post subject: |
Jaguar wrote: |
My SB8K SM has the OEM cans for now. |
I got some carbon end cans made at a local exhaust place for mine.
LucasJ
Posted: Wed Jul 13, 2022 3:14 am Post subject: |
It’s been way too long since posting any progress. Finally got around to working on this again.
Caswell coated the tank near the heat damaged area - turned out great
Worked on the exhaust situation. Tried to salvage what I could from the old system. Turns out the inlet and outlet caps are solid! Also all the brackets are restorable.
Also… they fit 1098 cans pretty well!
Will rivet them together and post the outcome. Just a tad shorter.
Also sourced a proper fuel connector from a shop in France. One had melted
Am happy to say that this machine is 98% restored. Exhaust fitting and some minor wiring for the tail lights and we’ll be in business. New chain and rubber too. Smells really good
