YB5 Rear Wheel Wanted
PaulDB2
PostPosted: Sat Apr 25, 2020 4:02 pm    Post subject: YB5 Rear Wheel Wanted Reply with quote
Long shot I know but I am looking for a rear wheel for my YB5. It is the 18" Akront-Marvic type with 3 spoke centre and bolted on Akront rim.
YB5 currently fitted with 17" Oscom, would be nice to get it back on original spec. wheels.
Cheers.
fish
PostPosted: Wed May 06, 2020 1:42 am    Post subject: Reply with quote
Hi buyee Japan has a front and rear on at the moment
DB1-DB2SR-DB2EF-DB3-DB4 Db10 YB6-yb7_yb10-2xyb11-SB5,2xSB6-kb3-yb5-MILLE MIKEHAILWOOD HARRIS MAGMAN2-TRIUMPH T140-RG500x2-KAWA Z900-SUZUKI GSX1100-DUCATI 900SS- 750 sport ducati DUCATI F1 750- 851 tri colour-500sl-1996 Trumph datona . Vee two alchemy
View user's profile Send private message Send e-mail Yahoo Messenger
PaulDB2
PostPosted: Wed May 06, 2020 8:47 am    Post subject: Reply with quote
Hi Fish, thanks for the heads up!
fish
PostPosted: Wed May 06, 2020 9:52 am    Post subject: Reply with quote
No worries
ruffef
PostPosted: Wed May 06, 2020 3:57 pm    Post subject: Reply with quote
and if you get those, and want to move on the wheel you've replaced, i just need the disc really....
fred
still looking....
PaulDB2
PostPosted: Thu May 07, 2020 12:00 am    Post subject: Reply with quote
Which disc are actually after?
ruffef
PostPosted: Thu May 07, 2020 9:34 am    Post subject: Reply with quote
YB6. It's a 230mm brembo cast steel, it's cracked clean through.
As i'm running 17" oscom wheels i'm guessing it might be the same as your current disc.
The disc is similar to this one for the SB6, but is sold, with the aluminium centre.
https://www.ebay.co.uk/itm/BIMOTA-SB-6-1994-REAR-DISC-5MM-THICK-AS-PER-PHOTO-RARE-LOT62-62C4527/233352794178?hash=item3654e91042:g:vwUAAOSwEX1djYR8
fred
still looking....
PaulDB2
PostPosted: Thu May 07, 2020 11:17 am    Post subject: Reply with quote
I'll bear you in mind if I get it and decide to sell the one currently fitted.
PostPosted: Fri May 08, 2020 7:55 am    Post subject: Reply with quote
fred
If your running "Oscam" wheels.....its a 230mm rear disc yup......and you have the alloy carrier but just need the disc?......if so I should be able to help
