bimsb8
Posted: Sun Mar 27, 2011 9:57 pm Post subject: DB2 SR tank |
Hi!
I,m looking for an SR tank (injektion) to my Db2 can somebody help me?
/Lars |
Catimann
Joined: 05 Mar 2011 Posts: 16 Location: Vancouver, Canada
Posted: Fri Apr 01, 2011 6:25 am Post subject: |
The SR tank would have a pump in it, rather than a gravity feed system, right?
Have you tried Ducati ms?
Will keep my eyes open. _________________ Andreas
93 DB2SR, 74 MG Eldorado, DRZ400SM
Searching for Tesi ES or EF |
bimsb8
Posted: Sat Apr 02, 2011 7:29 pm Post subject: |
| Catimann wrote: |
Will keep my eyes open. |
Yes, I,m looking for a SR tank with pumphole ,
I try Ducati ms also/thanks
/Lars
Db2,Sb8r,Kb1/a |
Catimann
Posted: Sat Apr 02, 2011 11:00 pm Post subject: |
Would it be possible to convert a stock DN2 tank? Cut a hole, mount a pump and ??? _________________ Andreas
bimsb8
Posted: Sun Apr 03, 2011 9:39 am Post subject: |
| Catimann wrote: |
| Would it be possible to convert a stock DN2 tank? Cut a hole, mount a pump and ??? |
I think plastic (fat) material make problem with mounting, I must have an mounting plate in alu to pump.
Problem to mount alu-plastic without leak.
Maybe some know better? |
Posted: Sun Apr 03, 2011 9:52 am Post subject: |
Lot's of plastic tanks out there (SB6R for one) with fuel taps senders and filler caps mounted in them
Seems O rings are the preferred method to stop leaks. |
bimsb8
Posted: Sun Apr 03, 2011 7:09 pm Post subject: |
| oily wrote: |
I know, but mounting in a selfmade hole is not same! |
Posted: Sun Apr 03, 2011 7:24 pm Post subject: |
And there was me thinking a hole was a hole  |
