Ignition timing
Gilles
PostPosted: Sun Sep 29, 2019 6:47 pm    Post subject: Ignition timing Reply with quote
Hi v-due's men
How can we check and / or adjust the ignition advance point on our wonders?
Thanks
Gilles
Moreno
PostPosted: Sun Sep 29, 2019 7:18 pm    Post subject: Reply with quote
to be able to modify it, new phonic wheels must be created to let the phase sensor read a different position .... unfortunately the pegaso ecu no longer has the software for editing
Moreno
Gilles
PostPosted: Wed Oct 02, 2019 11:39 am    Post subject: Reply with quote
OK Thanks
But how can we know which position of the phonic wheel we have the ignition point
sorru for the bad english
Gilles
Moreno
PostPosted: Thu Oct 03, 2019 6:05 pm    Post subject: Reply with quote
Gilles wrote:
OK Thanks
Gilles
in the phonic wheel 2 teeth are missing, and that is the moment when the signal reaches the control unit .... then the control unit delays the advance
Gilles
PostPosted: Sun Oct 06, 2019 4:09 pm    Post subject: Reply with quote
OK, thanks
but no means of engine control running
valer
PostPosted: Tue Jan 14, 2020 9:15 pm    Post subject: Reply with quote
Hello Gilles... les logiciels de réglage des systèmes électronique installés en série sont jamais distribués ou commercialisés... tout ce qu'on peut faire, c'est s'assurer que les capteurs et autres sont conformes à ce qu'à prévu le constructeur. Mais si tu veux un système fournit avec le logiciel de réglage, il y a celui que je commercialise pour la VDue. Dis moi si tu veux des infos.
Hello Gilles... the software of adjustment of the electronic systems installed in series are never distributed or commercialized... all we can do is to ensure that the sensors and others are consistent with what the manufacturer has planned. But if you want a system that comes with the tuning software, there’s the one I sell for Vdue. Tell me if you want information.
PROMAP for the job... VDUE for the love.
Gilles
PostPosted: Fri Jan 24, 2020 9:11 am    Post subject: Reply with quote
Yes i want information
Thanks
JackJabba
PostPosted: Mon Mar 09, 2020 10:03 am    Post subject: Reply with quote
Contact Gufi on this forum. He is a V Due expert and sells parts for the VDUE.
