pkay
Posted: Mon Dec 02, 2019 4:40 am Post subject: SB6 Shennanigans |
Never being one to leave well enough alone I want to ditch the pod air filters and return my SB6 back to a standard airbox set up.
But, someone has moved the battery to the airbox position and there is only one instead of the standard 2. I fear what someone has done to the wiring to get to this position. Here we go again.......
Easy question to start, what is the spec of the OEM batteries for the SB6? Brand and type would be great.
Ta _________________ pkay
Posted: Mon Dec 02, 2019 2:18 pm Post subject: |
Depends on the SB6.
The early ones had 2 x 6v batteries in series , the later ones had 2 x 12v in parallel. Only real difference was the the link wires between the batteries , and as you don't have them I guess you can go with either set up.
So whats the SB6 ? MK1 or 2 ? |
pkay
Posted: Tue Dec 03, 2019 2:03 am Post subject: |
| vort28 wrote: |
Depends on the SB6.
What's the difference between a Mk1 or Mk2? _________________ pkay
Posted: Tue Dec 03, 2019 5:49 pm Post subject: |
| What wheels has it got?...3 spoke Oscom BImota branded with flat ribs.....or 3 spoke Marchenesi wheels or Antera swirly 3 spokes? |
Posted: Tue Dec 03, 2019 7:44 pm Post subject: |
Easier ... do the brake and clutch have separate fluid reservoirs or are they the black all in one with the master cylinders _________________ Don't read everything you believe |
pkay
Posted: Thu Dec 05, 2019 12:08 am Post subject: |
| Evilchicken0 wrote: |
| Easier ... do the brake and clutch have separate fluid reservoirs or are they the black all in one with the master cylinders |
Separate, all in one that sounds like solving a problem that didn't exist....  _________________ pkay
Posted: Thu Dec 05, 2019 11:16 am Post subject: |
| pkay wrote: |
Separate, all in one that sounds like solving a problem that didn't exist....  |
They changed from Suzuki parts to Brembo Goldline _________________ Don't read everything you believe |
pkay
Posted: Fri Dec 06, 2019 12:26 am Post subject: |
No I've got the good old Suzuki ones. _________________ pkay
Posted: Fri Dec 06, 2019 2:55 am Post subject: |
| pkay wrote: |
| vort28 wrote: |
Depends on the SB6.
What's the difference between a Mk1 or Mk2? |
2nd engine mount hole in main frame spars, clocks, master cylinders, headlights, very slight differences in bodywork, wheels, brake rotors, switchgear, batteries _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Fri Dec 06, 2019 10:12 pm Post subject: |
| pkay wrote: |
| No I've got the good old Suzuki ones. |
That's a Mk 1 then. _________________ Don't read everything you believe |
Gammaboy
Posted: Sat Dec 07, 2019 3:19 am Post subject: |
You'd have to be thick to put the hard to find 6Vs in it.
Pretty sure Centrepoint have an airbox on the parts SB6 they have.
At a guess, they'd have extended the earth cables, moved the starter relay from behind the headlight to the side of the battery box and extended the power feed from behind the original state relay position. |
Gammaboy
Posted: Sat Dec 07, 2019 3:24 am Post subject: |
Also, last time I looked at the parts bike it was complete enough for you to be able to look at the wiring as it originally was. They may have pulled it apart since though.
And why is this in the bikes for sale forum? |
