Vic on the Coast
Posted: Sun Sep 26, 2010 2:51 pm Post subject: DB6 DELIRIO ECU & Fuel Injection |
Hello Everybody,
Just got my hands on a DB6 , but am experiencing some problems with the fuel injection . Bike will need to be tuned and/or re-programmed. However, closest Bimota service centre is much to far away, so I thought giving my KTM mechanic a chance to go at it.
Anyone that can give us some insight on what ECU and software this bike runs?
Would greatly appreciate any info on this matter, or anything else on the fueling system on this bike.
Regards
Vic |
waldorf
Posted: Fri Oct 01, 2010 1:35 pm Post subject: |
It's probably running the same Magnetti Marelli as the Ducati Monster but tuned by Bimota.
The very best you can do is to buy a Microtec ECU and have it tuned by any good mechanic with a dyno. _________________ Olivier |
Posted: Fri Oct 01, 2010 4:25 pm Post subject: |
maybe see if there's a power comander map listed either for the DB6 or 5 or a Ducati with the same 1000 DS motor. Then have it mapped using that as a starting point. _________________ Don't read everything you believe |
Brad
Posted: Fri Oct 01, 2010 4:38 pm Post subject: Power Commander |
All the power commander 3 series are the same with different software for max rpm.
If you get stuck you can hard wire a pc3 onto the bike and use the injector one channel(this gives the rpm input to the pc3) for one cylinder and injector two for cylinder two.
I've done this a few times when they weren't available for a particular bike. |
zombie
Posted: Fri Oct 01, 2010 8:23 pm Post subject: |
| ...might be worth checking the simple stuff: plugs, the TPS setting, manifold air leaks, carb balance etc, b4 you start spending out though... |
delirio1100
Posted: Fri Mar 04, 2011 9:19 am Post subject: |
I managed to adopt a PC5 with Autotune to the DB6.
Removed cats as well:
bimotaspirit
Joined: 07 Mar 2011 Posts: 2 Location: Raleigh, NC USA
Posted: Mon Mar 07, 2011 11:32 pm Post subject: DB6 ECU |
The DB6 has a Pegaso ECU and both built in diagnostics/map upload capability AND a mini-tune feature which is essentially a Power Commander. The diagnostic kit comes with software and the special cable to connect to the connector under the dashboard. For more information - contact me at: info@bimotaspirit.com Afer about 600 - 1000 miles the throttle body butterflies should be synchronized and the idle set, and then the TPS reset to zero electronically. _________________ Bob Steinbugler |
PhilG
Posted: Tue Oct 23, 2012 3:30 pm Post subject: |
| delirio1100 wrote: |
My front pipe is damaged, do you have the old one for sale? what improvements will it give without the cats? where can i but this from? |
