375NE
Posted: Mon May 27, 2019 6:38 am Post subject: SB6 engine parts help please |
Hi, I have SB6#254 and it is getting an engine overhaul and I am in need of a head gasket... now the one sent from suzuki is for engine type U709 and my engine is, apparently, type U712 (numbers have been relayed to me via engine builder).
Does anyone have the correct Suzuki part number for the head gasket or indeed engine gasket set for this engine...suzuki NZ say it is an unusual engine and have no record of a type U712....which worries me somewhat!!
Can anyone shed any light onto the numbers and the differences or even better, a part number for the required head gasket?
many thanks |
rudadue
Posted: Mon May 27, 2019 10:35 am Post subject: |
hi there i had a look on the net Fowlers motorcycle parts in the uk
basically its a tl1000s engine the front head gasket part no. is different to the rear cylinder head gasket 11141-02F01-000 is the rear
the front 11141-02F01 but later engines the rear cylinder head gasket part no. 11141-02F01 same as front head gasket
suzuki u712 engine 1997-2001
hope this of some help
good luck in your quest regards bill |
Posted: Mon May 27, 2019 11:33 am Post subject: |
| rudadue wrote: |
I doubt it's a TL1000 engine if it's in a SB6 _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Mon May 27, 2019 11:35 am Post subject: |
I'm not sure about the 'U' numbers but the engine should be out of the GSXR1100 W model. A Suzuki dealer should be able to identify it. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
rudadue
Posted: Mon May 27, 2019 4:13 pm Post subject: |
Hi all u712 relates to the tl1000 engine fitted to the SB8 models and not
sb6 so my apologies there as when looking on the web suzuki u712 realate to the vee twin lumps not the re-worked gsxr1100 lump (1127cc) sorry for duff info regards bill |
375NE
Posted: Mon May 27, 2019 11:32 pm Post subject: |
| So if I search online for GSX-R1100WR it gives me two options; GSX-R1100WR(E2)R and GSX-R1100WR(E28)R. are there any differences that would make one more likely than the other? |
Gammaboy
375NE
Posted: Tue May 28, 2019 5:05 am Post subject: |
| scratch that last question...apparently its differences not related directly to the engine. |
375NE
Posted: Tue May 28, 2019 5:07 am Post subject: |
Thank you Gammaboy.... thats cleared that up!!  |
Posted: Tue May 28, 2019 6:33 pm Post subject: |
OK - the engines for the SB6 were supplied by Suzuki who put on a different engine code (U712) but the engines are GSXR1100W … the MK1 Sb6 has the 1993 type and Mk 2 or later uses the later 95 type which has the extra frame mount to the rear of the engine head.
Very late Suzukis used a revised camshaft profile which was a "Yoshi" type. You can fit 750W cams to get a similar effect, the other cam lobes aren't centered on the cam buckets.
It's a good idea to check which cams are fitted to your engine - look for a letter stamped into one end - beware the C cams … they're restricted to 100bhp …. ask me how I know that's how Bimota restricted these bikes _________________ Don't read everything you believe |
