Ultrasonic cleaner
Goto page Previous  1, 2, 3
PostPosted: Fri Mar 22, 2019 1:49 am    Post subject: Reply with quote
They carbs have come up great!
Love the tea strainers, far superior to my fly wire creation!
I noticed the air screw needle orings aren't among your smalls. They will probably be up in the carb bodies, you can easily get them out with bit of hooked lock-wire. It's best to replace them. I found a good viton match at my bearing supplier.
PostPosted: Fri Mar 22, 2019 2:26 am    Post subject: Reply with quote
I had the pilot orings out. I left all of the rubber parts and gaskets out of the ultrasonic cleaner as I wasn't really sure how they would go. Thanks
Gammaboy
PostPosted: Fri Mar 22, 2019 5:24 am    Post subject: Reply with quote
What did the cleaner set you back Brian?
PostPosted: Fri Mar 22, 2019 6:57 am    Post subject: Reply with quote
From memory it was just under $300 Ben. This one is 22L, smaller ones are cheaper but i wanted one that I could fit a rack of 4 carbs in without having to split the rack up. There's a bigger 30L model as well, same size but deeper.
Page 3 of 3
