Horseheed
Posted: Tue Oct 16, 2018 8:21 pm Post subject: SB6r low fuel warning light trouble |
Hi all, iam having trouble with my low fuel warning light , it lights up for a few seconds when I switch the ignition on then goes out , even if the tanks full or empty . Has anyone had the same trouble or more importantly does anyone know how I can get it too work Cheers all _________________ Horseheed |
Gammaboy
Posted: Wed Oct 17, 2018 11:03 pm Post subject: |
Is it not doing that to confirm the bulb works? |
Horseheed
Posted: Thu Oct 18, 2018 5:16 am Post subject: |
Hi Gammaboy, that's what I thought, I was trying to find out if anyone has had the same trouble and how they cured it Cheers for the reply _________________ Horseheed |
O_Roger
Posted: Thu Oct 18, 2018 11:16 am Post subject: |
The common fix is to unscrew the bulb. The indicator is, if fully functioning, useless anyways. Just orient yourself on the Km Clock.
My SB6 is good for >160km. |
Posted: Fri Oct 19, 2018 10:32 am Post subject: |
Reset the trip when you fill up _________________ Don't read everything you believe |
Posted: Fri Oct 19, 2018 11:41 am Post subject: |
Evilchicken0 wrote: |
Reset the trip when you fill up |
+1 _________________ Bimota SB6 and Benelli TNT 899S road bikes.
SuziEngine2
Posted: Sun Dec 16, 2018 12:20 am Post subject: Re: SB6r low fuel warning light trouble |
Horseheed wrote: |
Hi all, iam having trouble with my low fuel warning light , it lights up for a few seconds when I switch the ignition on then goes out , even if the tanks full or empty . Has anyone had the same trouble or more importantly does anyone know how I can get it too work Cheers all |
It's supposed to do that. It runs the fuel pump for the same couple of seconds.
Sorry for late response, been away for a while. _________________ 1998 Bimota SB6R
1982 Suzuki GS1100SZ Katana |
Posted: Mon Dec 17, 2018 10:29 am Post subject: |
my SB6R had a vacuum fuel pump (which I have since removed). _________________ Bimota SB6 and Benelli TNT 899S road bikes.
