Falcolion
Posted: Thu Aug 09, 2018 5:18 am Post subject: YB11 radiator cap |
I am wondering if anyone figured out which radiator caps will fit YB11.
There is no way that Bimota used proprietary radiator caps. It would completely financially and technically unreasonable to do so.
Any knowledge and ideas would be appreciated
thanks
Vlad _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
2007 Aprilia RSVR Bol D'Or
2006 Bimota SB8K Santamonica
2005 Benelli Tornado Tre
2002 Mondial Piega |
Posted: Thu Aug 09, 2018 5:09 pm Post subject: YB11 rad cap |
SB6R also uses the Thunderace rad, but has a remote rad neck, for access. Bimota used a neck and associated cap that were nothing to do with the Thunderace. I couldn't find a similar cap, so ended up getting a neck made up, that would take a readily available cap. _________________ What, Jonny's gone! |
Falcolion
Posted: Thu Aug 09, 2018 5:33 pm Post subject: Re: YB11 rad cap |
| Jonny B Bad wrote: |
| SB6R also uses the Thunderace rad, but has a remote rad neck, for access. Bimota used a neck and associated cap that were nothing to do with the Thunderace. I couldn't find a similar cap, so ended up getting a neck made up, that would take a readily available cap. |
That is exactly the case. Radiator is a Thunderace but it has a remote Bimota specific Aluminum pipe with the cap _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
rudadue
Posted: Thu Aug 09, 2018 8:27 pm Post subject: |
Hi guy if you look at radiator filler neck adapter there are a few on eBay around £22 similar to original might help regards
[/img] |
Falcolion
Posted: Thu Aug 09, 2018 8:38 pm Post subject: |
| rudadue wrote: |
[/img] |
Do you have a link to an eBay?
Thanks _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
rudadue
Falcolion
Posted: Fri Aug 10, 2018 6:02 pm Post subject: |
Thank you. Unfortunately will not work with YB11. YB11 basically has a custom pipe with radiator filler neck and filler neck has a weird size. So any regular radiator caps don't work _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
Posted: Thu Aug 16, 2018 11:32 am Post subject: |
Ummmm, may I ask how you know the YB11 cap is a special-weird size?
How sure are you that all regular sizes are incompatible with the YB11?
Do you have one there to reference? If so you have your answer.
I can say it is doubtful that bimota manufactured a special radiator cap and filler neck for the YB11? Highly unlikely.
When you say... quote "Thank you. Unfortunately will not work with YB11. YB11 basically has a custom pipe with radiator filler neck and filler neck has a weird size. So any regular radiator caps don't work"
I think... bullshit. Or you have some special secret agent insight? I will post a pic of a filler that was was on a bike that I wrecked. It's still here, as I see it every now and then. Next time I trip over it I'll check for you.
Really, does it need to be this dramatic? I hope the picture is not too large... Cheers
Posted: Thu Aug 16, 2018 12:27 pm Post subject: |
Yep, it’s too large  _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Falcolion
Posted: Mon May 20, 2019 6:55 am Post subject: Radiator cap |
Ok, here is the deal. I was able to figure out which radiator caps fits remote neck of radiators on YB11. Any KTM, Husquarna and Husaberg radiator caps will fit just fine. The only problem with these caps is that stock cap on YB11 is 1.1 psi and the one from KTM is 1.8. Lowest that I was able to find.
Basically I took radiator cap from my Husaberg FE390 and it fits perfect. No leaks.
Radiator caps from any of the Japanese bikes would not fit and so are the one from Aprilia or newer Ducati _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
Gammaboy
Posted: Tue May 21, 2019 1:49 am Post subject: |
Who - the issue is the height of the the top seat of the neck vs the lower seat - most caps are designed with a shorter height - a handfull of bikes use this same taller standard. I measured a RSV4 neck I had on hand and the bimota neck - it's the same height (about 5-6mm taller than the Suzuki neck I had kicking around)
The cap from an RSV4 Aprilia fits the Bimota neck, and is only a 1.4 bar rather than the KTM/Husky/Husaberg 1.8 - the RSV4 guys fit the KTM/Husky/Husaberg 1.8 to gain some cooling capacity on the track with the stock rad. |
Falcolion
Posted: Tue May 21, 2019 7:31 pm Post subject: |
| Gammaboy wrote: |
Gammaboy,
Did you actually fitted the Aprilia radiator cap? Do you have a picture of your Aprilia radiator cap _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
Gammaboy
Posted: Tue May 21, 2019 11:07 pm Post subject: |
RSV4 radiator cap fitted to Bimota neck:
Falcolion
Posted: Tue May 21, 2019 11:20 pm Post subject: |
Is it Flat on the bottom (the part that goes into the neck)? _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
