rudadue
Posted: Sat Jul 07, 2018 8:15 pm Post subject: V-Due clutch spring collars update |
Hello Bimo's, mail arrived ducati anodized clutch spring collars hot footed to man cave and removed clutch cover and these puppies fit straight on same dimensions so going to order stainless steel clutch springs and red anodized
clutch collars and some nice titanium gold allen bolts so dry clutch should look a bit special happy days enjoy the w/end regards to all bill |
Posted: Mon Jul 09, 2018 2:53 pm Post subject: |
Hodo Rudadue….hopefully you havent ordered Duc parts yet...other than the "topHat" anodised caps that are held on by the bolts that compress the springs.
Check sizes......although clutch plates fit the Vdue basket....theres less of them....the basket is not as deep as on a ducati....thus....I am thinking the springs and the bolts are also shorter....and thus Duc ones no good...I already know the clutch pressure plate from the Vdue is not interchangeable with those used on Ducatis |
rudadue
Posted: Mon Jul 09, 2018 5:15 pm Post subject: V-Due clutch spring collars update |
Hi 2bims , i have only bought top hats i,e 6 and the titaniun retaining M6 bolts i will cut down to 16mm same as V-due so i presume the spring from a duke are longer than the v-Due ones thxs for heads up regards and thxs Bill |
Posted: Mon Jul 09, 2018 7:27 pm Post subject: |
Top pressure plate on Vdue is also different design to Ducati, springs are recessed into plate were a Duc they are sort of on top of it.( tried an anodised duc plate )
Although Vdue clutch looks similar to Duc one , everything is different. Basket attaches to shaft differently etc , why use carry over available items when you can design your own ??? |
rudadue
Posted: Thu Jul 19, 2018 7:18 pm Post subject: |
Surely then it would be a case of drilling Duke top plate , so springs sit as per V-Due or have i missed something here regards all |
Posted: Mon Jul 23, 2018 7:28 pm Post subject: |
Different clutch basket design, so top pressure plate different design to match baskets.
Spring collets probably the same but springs probably different spring rate/length , although never tried Ducati ones in vdue. |
