CBar
Posted: Tue Dec 14, 2010 6:06 pm Post subject: |
Are you saying that these will fit all of those fork sizes? |
Posted: Tue Dec 14, 2010 6:10 pm Post subject: |
After emailing them, asking if they would fit 46mm forks, I received a reply from them in very broken english saying that either these would fit all three sizes OR they had all three sizes in stock. I've ordered a set to fit 46mm forks so I'll let you know for sure when they arrive  |
CBar
Posted: Tue Dec 14, 2010 6:26 pm Post subject: |
Thank you. I also emailed them for a part number/product code. |
CBar
Posted: Tue Dec 14, 2010 10:16 pm Post subject: |
I got the same type of response. I asked for the product code and it is different than the one listen in the 46mm RSU manual. I asked for some measurements, but I haven't received a response yet. I don't see how the adjusters can fit 3 different diameters. |
Posted: Tue Dec 14, 2010 10:57 pm Post subject: |
Their exact reply to me was "you go up Paioli/Bimota 41, 43, 46"
I stressed that i needed them for 46mm forks so we will see what happens  |
Posted: Tue Dec 14, 2010 11:08 pm Post subject: |
I saw them a while ago and after I'd looked at the picture really really hard I though they're the standard type adjuster like the ones on my bike
The posh adjusters have a tall blue anodised adjuster to them. _________________ Don't read everything you believe |
Posted: Tue Dec 14, 2010 11:31 pm Post subject: |
I really hope they are preload adjusters and not the normal damping adjuster like yours
At £90 they will be going back if the are not preloders
Soon, we will see  |
Posted: Thu Dec 16, 2010 9:54 am Post subject: |
OK guys.....
They've arrived and..........They are NOT preload adjusters
They are compression valves that fit into standard fork tops DOH..
I'll see if they'll take them back unless anyone has got chewed up adjusters and want to buy a bargain pair  |
Posted: Thu Dec 16, 2010 12:06 pm Post subject: |
That's a shame. The preload adjusters were an optional upgrade for the Paioli forks so it would follow they would / should have the kits arround but it doesn't seem possible to contact them. _________________ Don't read everything you believe |
Posted: Thu Dec 16, 2010 12:56 pm Post subject: |
Yes, an optional extra for the 6 and standard for the 6R. I've got them on the other 6 but thought I'd get some for the new toy. Never mind
Paioli's product code is 849-311-526 for 46mm pre-load adjusters
And your right.... the factory doesn't reply to emails  |
Posted: Wed Jan 05, 2011 1:43 pm Post subject: |
Oily , what exactly are they ? the threaded part with the brass screw in the center ? |
Posted: Wed Jan 05, 2011 1:51 pm Post subject: |
They are the compression adjusters that sit in the middle of the fork tops.
They would sit in the middle of the pre-load adjusters if you've got them
Got a pair going cheap if you need them  |
Posted: Wed Jan 05, 2011 2:18 pm Post subject: |
You have any pictures and rough dimensions ? I think these are common with all paioli forks , just want to check.
What you after for them ? |
Posted: Wed Jan 05, 2011 2:32 pm Post subject: |
Your right.....they are common to all RSU paioli.
Thread is 18mm approx
across the flats is 14mm
total length is 36mm
I paid £76 and I'd like as much of that back as I can get
Be back with pictures shortly  |
