				 Posted: Sat Jul 09, 2016 10:23 am    Post subject:  |
				Must be nearly time for an update on the saga? _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
				 Posted: Sat Jul 09, 2016 4:16 pm    Post subject:  |
				| LOng overdue I agree....sadly still waiting for engine...as after that its merely a half day to put back together....no parts needed, all new bolts ready etc etc....all other bits painted, cleaned, refreshed, polished what have you....just crying out for my engine back...... |
		Gavin944888
				 Posted: Thu Jul 14, 2016 7:35 pm    Post subject:  |
				2Bims......who have you entrusted the engine to?
Regards
Cagiva Elefant 999r engined
Cagiva BIMOTA Motard Concept
				 Posted: Thu Jul 14, 2016 8:10 pm    Post subject:  |
				My "Local" Main Ducati Dealer, Ducati Manchester...which is less than a mile from mine.........Have used them before and often find spares can be cheaper direct than from ebay for hard to find parts.....I do just drop the engine off though...as at least that part they are familiar with...although they have gotten used to dealing with Bimotas over the years with me.....Thy have a sister shop near Preston that used to be a Bimota dealer....but just once for a year...as they found the back-up from the factory completely non-existant.....and Bimota not paying for Warranty issues....so had to cover these themselves...once bitten twice shy I'm afraid.
Dealing with lads there that I know over the years....on "mates rates"...not such an issue to throw it back together...but I was after a main dealer "comeback" if one of the bolts was to fail again...or the engine have leaks etc....thought it best to pay a little extra for the potential effort that may be involved... |
				 Posted: Tue Aug 09, 2016 9:41 pm    Post subject:  |
				Long overdue Update....And the good news is...."She lives....".......Engine was picked up on Saturday and inbetween rain showers and sun I've spent the last 3 days reassembling and sorting electrics......But...come the first splash of 2 litres of 97 grade.....she fired up on fourth prod after priming the carbs....and a couple more prods to get her to accept a tickle from the throttle to rev cleanly and then idle at 1,000 revs or so....and so far so good...all electrics working...........Will update with pictures before she sets herself on fire...as I did have a slight fuel leak from the Low fuel warning sender unit....seal must have dried out with the tank being empty for the last 2 months....which then promptly leaked onto the heat shield after which it drops it onto the rear header....Oops......      Fortunately I spotted it and temp plugged it before she went up in flames.....so a little more work needed yet |
				 Posted: Thu Aug 11, 2016 5:46 pm    Post subject:  |
				I promised a few pictures so here goes......Finally back together and running...and I dont have any spare bolts left either which is a first...well..apart from the fairing and seat/tank unit bolts that is which arent fitted yet.....
Nice new Push pull throttle cables and twist fitted...getting hard to find nowadays with the advent of fuel injected engines...
New Oil line banjo bolts and lines
Polished rear header already going a nice golden colour with first start up....and rear valve cover powder coating and barrel and head paint holding up so far also.....
Shiney front header going the same way
Oil line fixings cleaned up nicely....
Nicely made down and up exhaust system to fit in front of swingarm and offset for rear shock....
Newly powder coated Ohlins spring, colour change from red....
Oil and filter change tomorrow now that I've tested the engine out on first fill of oil...
Rear concentric adjusting spanners still attached until I refit the chain and adjust the chain properly...
Record mileage for date of rebuild status...
K&N cone filters have been cleaned and re-oiled....
and now step back pictures for the big-ish....reveal...
So.....An oil change and filter....refit chain and front sprocket,,,clothes back on and it'll be down the MOT station to hopefully get some use before Summers Over..........more piccies when fully dressed   |
		glened
				 Posted: Thu Aug 11, 2016 6:14 pm    Post subject:  |
				Hi Steve, The bike is a credit to you. Cant wait to see it in the flesh, we will have to get together when I return from my trip abroad. I may want some help in posting some pics from Switzerland. _________________ Bimota DB10, Suzuki TS250, Kawasaki Z1A, T120 Trton, AJS650, KTM690 Duke |
				 Posted: Thu Aug 11, 2016 9:12 pm    Post subject:  |
				| Will do Glen....and it would give you a chance to extend your riding experience of Bimotas by adding another model "ridden"....You'd like this one for sure.....very raw and addictive...and no silly slipper clutch, or fuel injection....just twist, hold on tight...and go....Tis also louder than the Db5R...and more characteristic with the flatslides and K&N filters.....a true symphony of engine noise |
		kenmoore
				 Posted: Thu Aug 11, 2016 9:52 pm    Post subject:  |
				Wow !
Something to aspire to with the Db1 . _________________ The Older I Get The Better I Was ! |
		v-pilot
				 Posted: Thu Aug 11, 2016 10:23 pm    Post subject:  |
				Cracking job!  Absolutely brilliant! _________________ 02 aprilia RSVR Mille, 02 aprilia SL1000 Falco
96 Ducati 900 SS/SP
78 Moto Guzzi V50
68 benelli 250 65 Ducati 250 |
		MRLost
  Joined: 27 Jun 2015 Posts: 19 Location: Cloudcuckooland
				 Posted: Fri Aug 12, 2016 2:30 am    Post subject:  |
				Fantastic job. Attention to detail really stands out. And I like your home-made eccentric chain-adjuster wrenches. Another great idea for all to copy, thanks to this forum. _________________ 2013 retro Italian agricultural device
2011 gigantic German go-anywhere motorad
2006 sensible Japanese dual-sport
1994 over-the-top Italian super-sport thriller |
		waggy
				 Posted: Fri Aug 12, 2016 7:17 am    Post subject:  |
				| Cracking job 2bims, well done. |
		kenmoore
				 Posted: Fri Aug 12, 2016 11:16 am    Post subject:  |
				Now get out and ride it mate, maybe some vids for all to enjoy !
I would love to hear what a fresh 900 sounds like . _________________ The Older I Get The Better I Was ! |
		kenmoore
				 Posted: Fri Aug 12, 2016 7:07 pm    Post subject:  |
				Thanks for that 2
Sounds and looks great. _________________ The Older I Get The Better I Was ! |
