		Mike Jennings
				 Posted: Sat Feb 27, 2016 5:05 pm    Post subject: Front wheel for SB3 |
				Hello,
 I'm looking for a front Campagnolo wheel for a Bimota SB3.
     Cheers, MikeJ |
		waggy
				 Posted: Sun Feb 28, 2016 5:56 pm    Post subject:  |
				Hi Mike, what's up with the one you have? The campag above, if it's like mine that can fit a Yam is wider across the hub and the standard brembos and carriers won't fit - the discs are too wide apart. Also you can't fit a speedo drive as you only have 10mm I think at either side. I had some carriers and discs made at a good price. Mailme and I can send you a couple of pics
Nige _________________ KB1x2, SB3 SB4 BB1 DB2 Vdue Evo YB11 RB1 Ducati MHR Suzi GS650 |
		Mike Jennings
				 Posted: Mon Feb 29, 2016 10:15 am    Post subject: SB3 wheel |
				Hello Waggy and Nige,
   thanks for the replies. The original Campag. was dented and Hagon's couldn't straighten it so it's out of action, unfortunately. I've fitted a replacement wheel which also needed special carriers made but it's a small flanged Speedline or something similar which doesn't match the rear Campag. so I thought I'd see if anyone had the correct wheel. There's no rush on the bike as I've been fiddling with it for about twelve years now- it'll probably end up being left to a museum in my will!
     Cheers, Mike   |
