Ultrasound cleaning
atomibart
PostPosted: Tue Apr 07, 2015 9:39 am    Post subject: Ultrasound cleaning Reply with quote
Hello from France
I would need some feedback from members of this forum cause I want to clean injectors of one of my Bimotas by ultrasound bath as I did for the carburettors of my Supermono before. But I heard here and there that this could not be done for injectors which I doubt...
So I want to be sure by asking you guys Smile
Thanks in advance for your technical advice
atomibart
PostPosted: Tue Apr 07, 2015 11:27 am    Post subject: Reply with quote
It might be better to contact the injector manufacturer and ask what they recommend
Weed
PostPosted: Mon Jun 15, 2015 11:56 am    Post subject: Re: Ultrasound cleaning Reply with quote
atomibart wrote:
Hello from France
atomibart
On a slightly different note, I bought an ultrasound bath a couple of years ago & not had any success in cleaning anything. Obviously operator error but I am using the correct chemicals for alloy in the bath, the temperature appears to be correct but is there a time limit to leave the items in the bath. I have only ended up with bad results. the bath is made by a reputable manufacturer in Australia but unfortunately they haven't been much help. if I weren't a couple of thousand miles away from them I would drop in and see them
PostPosted: Mon Jun 15, 2015 1:59 pm    Post subject: Reply with quote
I use water and some stuff http://www.amazon.co.uk/JPL-Ultrasonic-Cleaning-Solution-Cleaners/dp/B00187USI8
Mine's just a jewellery cleaner from Maplins so I only clean the small bits and float bowls in it but they work well enough. It doesn't make it shiney though
PostPosted: Tue Jun 16, 2015 6:36 pm    Post subject: Reply with quote
Hi Weed, when you turn on your ultrasonic does the surface of the liquid "dance"? How long are you leaving the parts in?
Spike C.
1965 Triumph T100SC
Weed
PostPosted: Tue Jun 16, 2015 8:12 pm    Post subject: Reply with quote
Good morning Spike. I haven't used it of about 18 months but I don't recall the surface dancing, only me in frustration.
I generally left the parts in for 30 minutes & when it didn't work I gave it another 30. I was working on a similar theory to the one that if you are speaking to someone who doesn't speak english then just talk louder & they will understand. Laughing
PostPosted: Tue Jun 16, 2015 9:38 pm    Post subject: Reply with quote
if the surface isn't moving then its likely the vibrating plate is fubbarred.....
PostPosted: Tue Jun 16, 2015 10:05 pm    Post subject: Reply with quote
Yes, your sonic is toast. Or defective. Either way you need a new one.
Sorry about that!
Spike C.
1965 Triumph T100SC
Weed
PostPosted: Wed Jun 17, 2015 1:38 am    Post subject: Reply with quote
Thanks guys. I will reload it and test it again. What effect does fluid the temperature have? I had that turned up to the max as well. About 80 deg C
PostPosted: Wed Jun 17, 2015 2:45 pm    Post subject: Reply with quote
The temp can soften oil and grease like using hot / cold water for washing up
rudadue
PostPosted: Wed Jun 17, 2015 6:01 pm    Post subject: Reply with quote
An other way would using ultrasonic cleaner but suspending injector so you can supply voltage so injector in the open position to get full benefit of cleaning, a bit it like throttle valve gumming up cause of egr exhaust gases being re introduced to inlet charge just a thought guys regards bill
PostPosted: Wed Jun 17, 2015 6:13 pm    Post subject: Reply with quote
Run the engine and spray carb ... or injector cleaner into it.
PostPosted: Thu Jun 18, 2015 5:40 pm    Post subject: Reply with quote
My DB5R had sticky injectors when I got it, I ran a few tanks with Techron injector cleaner in the fuel and it cleared up very nicely.
Vrooom Vrooom!!
Spike C.
1965 Triumph T100SC
