Another Italian electronic issue!
PostPosted: Wed Dec 03, 2014 12:32 am    Post subject: Another Italian electronic issue! Reply with quote
Ok, guys, this should be a an easy one. Bike is a 2007-8 DB5R with stock front turn signals and Ducati led rear signals. When I turn on the signals some of the time they work correctly, some times they light butt do not flash, just steady on. Any ideas as to what could cause this? It sounds like a dodgy flasher unit to me,any other thoughts?
Spike C.
1965 Triumph T100SC
PostPosted: Wed Dec 03, 2014 10:49 am    Post subject: Reply with quote
I'd have said the indicator relay or maybe a dodgy connection that's changing the overall resistance of the circuit.
Try a bulbed indicator on the front, if you have one to hand, just to check it otherwise use a different relay. My FZR400RR had a similar thing (4 cheap aftermarket bulbed indicators) I used a cheap relay from Halfords and now they're fine.
PostPosted: Wed Dec 03, 2014 12:31 pm    Post subject: Reply with quote
Disconnect your aftermarkey rear Units and see if the fronts flash OK.....then its to Evils thoughts that the flasher unit needs changing...also ensure the battery is up to speed with sufficient charge
Mike Jennings
PostPosted: Wed Dec 03, 2014 1:37 pm    Post subject: Reply with quote
Hello,
might be worth checking any earth connections as well,
Cheers, MikeJ
PostPosted: Mon Dec 08, 2014 11:48 pm    Post subject: Reply with quote
All of the lights function, and for the last couple of rides the flasher has been behaving. I wiggled a couple of wires in the rear and that seems to have fixed it for now!
A while back when I was looking to spend some money a suggestion was made to get an alloy bit that replaces the rear plate holder and signal mount. I had a bout of blingitis a few days ago and ordered one, when I install it I will scrutinize the rear more closely!
Spike C.
1965 Triumph T100SC
Garynuttall
PostPosted: Mon Dec 15, 2014 9:05 am    Post subject: Reply with quote
hey spike - if you havent sorted out the indicator issue - i had the same on mine - same bike db5r - all i did was wigggle the main connector housing that sits near the odometer for all the electrics and lights - been ok ever since...........regards
Loveitalianbikes
Garynuttall
Loveitalianbikes
PostPosted: Tue Dec 16, 2014 1:30 am    Post subject: Reply with quote
Thanks Gary, I'll give that a look see as well!
Spike C.
1965 Triumph T100SC
PostPosted: Thu Jan 15, 2015 9:12 pm    Post subject: Reply with quote
Well, I still haven't removed the side panel to look at the flasher unit, but yesterday while riding around the city I noticed that if I was stopped the lights would not flash, just steady on, and when moving, if I reved the engine enough to make some vibration they would work correctly. This is pretty consistent. If it was a loose wire I would expect an inconsistent result.
I think that I will order a flasher unit. Any recommendations on which one would be appropriate?
Spike C.
1965 Triumph T100SC
PostPosted: Thu Jan 15, 2015 10:21 pm    Post subject: Reply with quote
Got to a shop and explain what indicators and relay you have, they'll sell you one ...
