		SB6-RSF
				 Posted: Wed Jul 23, 2014 9:06 pm    Post subject: Sb6-R Speedo sensor needed!! |
				Hi all! Is there anyone out there that could tell me where I can get hold of the speedo sensor for my bike? I guess it`s the same for the YB11 and the V-due. I need the part number if anyone have it as well. Thanks in advance! From hopefull norwegian with a big grin on his face from finally driving his SB6-R after 6 years of ownership... _________________ HD: The best way to convert petrol into noise without the side effect of
horsepower... |
				 Posted: Thu Jul 24, 2014 9:57 am    Post subject: SB6R speedo sensor |
				If it's non-functioning clocks that are leading you to look at replacing the sensor, you are likely to find that it is the clocks that are at fault. They are not a well made item and are best put in the bin   _________________ What, Jonny's gone! |
		SB6-RSF
				 Posted: Thu Jul 24, 2014 4:32 pm    Post subject:  |
				The sensor is only partly there... Probably due to the excursion into the grainfield where it ended the motorcycle career for the previous owner. (He is OK BTW) _________________ HD: The best way to convert petrol into noise without the side effect of
horsepower... |
		SB6-RSF
				 Posted: Thu Jul 24, 2014 4:43 pm    Post subject:  |
				If the clocks are s***t, there must be easy to get hold of a sensor..? O
I guess a lot of people have converted into other brands of clocks/instruments? _________________ HD: The best way to convert petrol into noise without the side effect of
horsepower... |
				 Posted: Fri Jul 25, 2014 9:29 am    Post subject: SB6R speedo sensor |
				I'll see if I've still got one. Are there still some bolts in the disc bobbins? _________________ What, Jonny's gone! |
		SB6-RSF
				 Posted: Fri Jul 25, 2014 10:28 am    Post subject:  |
				Splendid! The 4 (I think it`s 4) bolts in the disc is still there! Will be very pleased if I could buy a working sensor from you!    _________________ HD: The best way to convert petrol into noise without the side effect of
horsepower... |
				 Posted: Fri Jul 25, 2014 7:56 pm    Post subject: SB6R speedo sensor |
				pm sent. _________________ What, Jonny's gone! |
