Race YB8 for Island Classic
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Tue Mar 25, 2014 12:05 am    Post subject: Reply with quote
Sorry to hear about the blown engine bud but glad that you managed to keep it ipright. Must have been a wild ride at the end of one of the fastest straights on the planet with the arse end locked up!
Beaut pics mate. All the best with the rebuild.
PostPosted: Tue Mar 25, 2014 12:36 am    Post subject: Reply with quote
Yep, my arse end was certainly locked up! Thanks for the good wishes. It looks like I've found a motor already.
Corse
PostPosted: Tue Mar 25, 2014 2:33 pm    Post subject: Reply with quote
Great to see a Bimota out there, I raced at the PI Classics in 2013 I suppose we would have raced the same class P6? I was on a 86 GSXR750 that I had restored, an old ex-racebike that competed at the Daytona 200 in 87. If I had an older Bimota I would have definitely raced that there, what a fantastic place!
PostPosted: Tue Mar 25, 2014 9:57 pm    Post subject: Reply with quote
Cool. PI is a great track isn't it?. I only started on the Bimota this year.
Here is a video of the moment she died. I'd already started tipping it into Turn 1 so I was lucky to keep it upright.
https://www.facebook.com/photo.php?v=10152655134404338
roy54
PostPosted: Tue Mar 25, 2014 10:24 pm    Post subject: engine woes Reply with quote
Sorry Bud to hear the engine let you down but you saved the bike and thats the main thing and after seeing how you rebuilt the bike i know you can sort it hope you have some luck finding a new motor can you keep us up to date cheers roy.
PostPosted: Wed Mar 26, 2014 7:17 am    Post subject: Reply with quote
[quote="brian"] Must have been a wild ride at the end of one of the fastest straights on the planet quote]
Oops... for some reason i thought you were at Phillip Island. Still, you did a great job to stay upright.
PostPosted: Fri Mar 28, 2014 3:34 pm    Post subject: Racing YB8 Reply with quote
Bud, I see you're running 8e/Furano fairing, with holes at the front to feed the holes in the frame that lead to the airbox, unlike original 8 fairing which has no holes in the fairing. What size jets are you using, assuming they're Mikuni and are you using original needles, if so which position is the clip? Have you got the paper filter in, or a K&N? I assume you're happy with the fuelling, if you're racing it? Sorry to hear about the engine blow-up. Any idea what caused it?
PostPosted: Fri Mar 28, 2014 10:55 pm    Post subject: Reply with quote
Good spotting Jonny. I've got the Furano fairing as it's the best raceglass I could find.
I run Keihin FCR41 flat slide carbs with the airbox and a simple pre-filter, so I can't help you with Mikuni jetting. My bike has (had Sad ) a pretty flat torque cuve from 6000-10500 RPM and nice fueling all the way through.
There is no EXUP on this bike so there is a lean hole at 4000RPM but this doesn't matter for a race bike.
Here is the main damage:
It looks like a rod bolt stretched, allowing the nut to come off. The big end then opened up over the crankpin and went flailing around.
daveg
PostPosted: Fri Mar 28, 2014 11:13 pm    Post subject: Reply with quote
I seem to recall from my youth that the Yamaha 1000 engines suffered Conrod failure if raced.
orteR
PostPosted: Fri Apr 18, 2014 6:25 pm    Post subject: Reply with quote
Bud977 I wish a speedy recovery.
Slovakiaring 13.4.2014
[img]http://s16.postimg.org/gembbawat/1506040_275793302595455_5831660003165522483_n.jpg[/img
[img]http://postimg.org/image/okj2hwk11/[/img]
orteR
PostPosted: Fri Apr 18, 2014 6:35 pm    Post subject: Reply with quote
PostPosted: Fri Apr 18, 2014 7:27 pm    Post subject: Reply with quote
Yowza! Knee on the deck and look at all of that clearance under the bike!
Spike C.
1965 Triumph T100SC
PostPosted: Wed Jun 25, 2014 7:21 am    Post subject: Reply with quote
I don't know about a bolt stretching, the big end has got very very hot prior to letting go (look at the colour of the rod and cap). Doing wheelies with the forward facing pickup will starve the engine almost immediately and lead to catastrophe. Whatever the case, it looks like a lot of heat was generated before it let go.
Overfilling these engines with oil slightly (OW01 kit manual) helps a little. A rod that looks like this is almost always a spun bearing. Think about deepening and baffling the sump on the next one, and keep your oil levels up. Cheers,
Ralph
PostPosted: Mon Jul 28, 2014 10:46 pm    Post subject: Reply with quote
How's things going Bud?
PostPosted: Tue Jul 29, 2014 12:29 am    Post subject: Reply with quote
G'day Brian, it's going slowly slowly.
This is the YB8 as it currently sits. It's getting a few minor adlustments Rolling Eyes Smile
The rod had punched a hole through the crankcases and damaged the crank so I bought a replacement motor. I pulled the new motor down to give it a full rebuild. The cases needed a good clean.
Here are the cases after a session in my new sand blasting cabinet. They're ready for re-assembly. It's nice to have a clean base to work from.
I'm waiting on the bearing shells and then the bottom end can start going back together again.
In the meanwhile, I'm rebuilding my VFR400 motor after it spun a big end bearing and hope to have it ready for the PCRA Wakefield One Hour meeting in a month's time. I'm looking forward to teaming up with my 16 year old son for the first time. Australia is behind the rest of the world and in NSW it is very difficult for Juniors to road race and you pretty well have to be a Senior (16yo+) to road race.
I've been concentrating on the Period 6 250 class on my TZ250A reverse cylinder and the Period 5 250 class on my RD250LC in the PCRA Club Championships. I'm leading both classes at the moment with two more rounds to go. Cool
I'll try to keep you posted on the re-assembly of the YB8 if you're interested. I'm aiming to ride the Bimota next at the Island Classic in January again so I've got a fair bit of time.
Page 4 of 8
