SB6 clutch problem
alanv
PostPosted: Mon May 27, 2013 5:30 pm    Post subject: SB6 clutch problem Reply with quote
Hi all. Got the SB6 home at last. Ordered fresh tyres, changed the fork oil, started it up and into first gear - now the clutch will not disengage. I have bled the line but no luck, so starting from the top I'll try to repair the master cylinder before trying to get to the clutch. I have looked for a Tourmax repair kit with no luck, so any suggestions on where I can get one would be appreciated. Failing that, I will need a replacement master cylinder - again, suggestions welcome.
Alan
PostPosted: Mon May 27, 2013 11:13 pm    Post subject: SB6 Clutch problem Reply with quote
It's far more likely to be a failed slave than master. Drop that motor!
PostPosted: Tue May 28, 2013 9:17 am    Post subject: Reply with quote
How long has the bike been sitting? Been in storage? Does it feel like there's pressure in the clutch line? It may just be that the clutch plates are all stuck together.
alanv
PostPosted: Tue May 28, 2013 5:24 pm    Post subject: Reply with quote
HI Jonny, you may be right about the slave cyl, can you repair it or is it a replacement im looking at.?.......HI Brian, the bike ran a few miles with no problem but the next day no joy, if I put the bike in first with engine off I can move the bike with a lot of effort if the clutch is fully in but no way rideable, cheers AL
PostPosted: Tue May 28, 2013 5:47 pm    Post subject: Reply with quote
You can buy a seal kit for it but if the piston is scored you'll need a new slave (£80) from Suzuki.
As said you'll need to drop the engine or swing it forward on the top mounts to take off the sproket cover, the slave cyl fits into the back of this.
alanv
PostPosted: Tue May 28, 2013 10:15 pm    Post subject: Picture Reply with quote
Anyone know how to post a pic? I've uploaded file but can't seem to find a way to get back to original page to save / submit.
Hursty
PostPosted: Tue May 28, 2013 10:23 pm    Post subject: Reply with quote
You have to load the photo onto something like photobucket and them cut and paste the image code into your post and your done Very Happy Very Happy
Remember to post lots of pic's of your bike you will be surprise how much we can tell about your bike with a few pic's. Wink
Hursty from kiwi land Smile
PostPosted: Fri May 31, 2013 3:26 pm    Post subject: Reply with quote
Hello Alan,
What’s the progress with your clutch problem, did you solve it yet Question
Still no pics …… need some help Question
vince
