Posted: Sat Jul 28, 2012 6:06 am Post subject: |
| Evilchicken0 wrote: |
| maybe you can big bore the 750 ? |
...Now we're talking  _________________ SB6 mk1 (project mega light, big bore)
Mike Jennings
Posted: Sat Jul 28, 2012 11:29 am Post subject: |
Hello Macx,
in Georgio Sarti's book he describes the SB2/80 as having the 'the same frame as the SB2' and that 'an SB2/80 with a Suzuki 1000 engine recorded a top speed of 232kph..', so it sounds like it's possible maybe with some mods. Some SB2 differences with the SB3 included the subframe on the latter and that the SB2 had sockets for the seat-tank unit prongs behind the steering head, and by the shock absorber, along with brackets for the rubber ties holding the back of the bodywork.
Good Luck,
MikeJ. |
Macx2
Joined: 03 Dec 2011 Posts: 44 Location: Wide Bay Queensland Australia
Posted: Sat Nov 03, 2012 10:38 am Post subject: |
Gents,
I did a big drive yesterday ( 850Kms) and picked up the SB2. The bike is more amazing than I previously thought. The glass work shaping on the tank is fantastic, as is the work on the frame. For 1978 this is so good.
I will post some photos later.
At this point I would like to get some original photos of this model for it's restoration. This bike is the second series with the horizontally spilt fairing.
Are there any Australian owners on this forum?
Importers are registered thieves as are the customs lot! Regards
Ian |
Macx2
Posted: Sat Nov 10, 2012 6:12 am Post subject: |
Well, after the dust has settled and I have had a close look all I can say is ....Fantastic:-
Ian |
Posted: Sat Nov 10, 2012 9:28 am Post subject: |
...Very Nice, that looks like someone has been carefully looking after it.....
and now it's your turn
congratulations your a very lucky git..sorry that should be guy...Freudian slip  _________________ SB6 mk1 (project mega light, big bore)
gorgeous looking bike,
well done
http://thecrankcase.com |
Posted: Sat Nov 10, 2012 12:09 pm Post subject: |
It looks cool huh
All those scoops and ridges make perfect sense once you tuck in behind the screen _________________ Don't read everything you believe |
Posted: Sat Nov 10, 2012 12:48 pm Post subject: |
Flash Gordon!  _________________ Pomps
Posted: Sat Nov 10, 2012 4:50 pm Post subject: |
... Cosmic Cheerleaders ??? _________________ Don't read everything you believe |
Macx2
Posted: Sun Nov 11, 2012 3:14 am Post subject: |
The body work is quite good but the engine will need a complete overhaul at which time I will get it painted again. The wheels need repainting in the correct colour and the brakes are needing work as well. When I get time I will take the bodywork off and post a few shots of the good, the bad and the ugly. The frame hugs the motor so tightly that the outer plug leads go around the frame to get to the outer plugs. It is all very interesting when you compare with other bikes selling at the time.
Ian |
Posted: Sun Nov 11, 2012 11:03 am Post subject: |
That sounds like Bimota they sacrifice everything to get the frame as right as possible and therefore make the bike small _________________ Don't read everything you believe |
