Josema
Posted: Tue Nov 24, 2009 8:10 pm Post subject: SUSPENSION SET UP DB7 |
HI FROM SPAIN
I HAVE A DB7 IN CARBON
I NEED INFORMATION ABOU SETUP OF THE SUSPENSION
THE BOOK INFORMATION IS NOT CORRECT
THANKS _________________ No creo ande en desiertos muy remotos ni en montañas muy lejanas |
Posted: Tue Nov 24, 2009 8:28 pm Post subject: |
Sorry, can't help with your question Josema but welcome to the forum  |
Posted: Wed Nov 25, 2009 3:52 pm Post subject: |
Welcome to the site! Best advise is to go to a suspension specialist with the bike ready to ride it and spend a few hours dialing it in with him instead of spending weeks chasing an error in the wrong direction on your own. Anyone's suggestions will only be relevant for them, we all ride differently on the throttle, on the brakes, sitting position, weight, ride position, etc. etc. The only thing to check on your own would be the front and rear sag prior to messing around with damping. The problem with high performance suspension is that the "sweet spot" is much a much narrower band of error and just 1 or 2 clicks either way can make you feel uneasy. Some riders can ride around a problem by not worrying and never adjust anything for road, track, touring however, if like me you sense every twitch and pressure through the bars and feet when your not expecting it then its worth getting expert help. Lack of confidence takes you off the throttle and bikes always handle better under power driving the suspension down keeping your seat a stable platform while the springs do their thing underneath you. Off the throttle the opposite effect causes the springs to push you up and down instead!
So, after all that... dont waste time just bite the bullet and see a man who can! _________________ Pomps
Josema
Posted: Fri Nov 27, 2009 11:04 pm Post subject: |
I SEND A MAIL TO EXTREMETE TECH AND TO MARRZOCCHI
THIS IS OF EXTREME TECH
For street you can try;
Bump Low: 9
Bump High: 6
Rebound Low: 9
Rebound High: 6
For circuit:
Bump Low: 7
Bump High: 5
Rebound Low: 5
Rebound High: 4
Click from all closed.
Regards
Distinti Saluti
Simone Galeazzi
E. ENGINEERING S.R.L.
Strada Pelosa 183
36100 Vicenza
tel. 0039 0444 240785
fax 0039 0444 240798
www.extremetech.it _________________ No creo ande en desiertos muy remotos ni en montañas muy lejanas |
Posted: Sat Nov 28, 2009 10:07 am Post subject: |
Can I ask how much you weigh? _________________ Pomps
Posted: Sat Nov 28, 2009 10:14 am Post subject: |
Also, what does the bike feel like when you ride it? Does it need a special effort to counter steer in? IS there a return pressure thru the bars once you lean into the apex? Does it weave under power out of the corner or into it? I can give you a rough guide of effect and reaction to clicking up or down if you can think about these questions?  _________________ Pomps
Josema
Posted: Sun Nov 29, 2009 4:44 pm Post subject: |
no tengo ni idea de lo que me preguntas.
yo peso 75 kg.
Estos son los reglajes standard para circuito y para calle.
Si te gustan bien y sino tambien.
Saludos desde España. _________________ No creo ande en desiertos muy remotos ni en montañas muy lejanas |
Posted: Sun Nov 29, 2009 5:13 pm Post subject: |
And here's the babelfish translation
I do not have nor idea than you ask to me. I weigh 75 kg. These are the settings standard for circuit and street. If you like well and but also. Greetings from Spain. |
Posted: Sun Nov 29, 2009 6:24 pm Post subject: |
nice one Oily, At that weight he should be in the ball park I guess. Let us know how ir performed Josema! _________________ Pomps
Josema
Posted: Mon Nov 30, 2009 10:13 pm Post subject: |
IN THE BALL PARK???
sin comentarios
simpatico  _________________ No creo ande en desiertos muy remotos ni en montañas muy lejanas |
Posted: Mon Nov 30, 2009 11:16 pm Post subject: |
ÁREA CORRECTA  |
bimotard
Joined: 24 Apr 2008 Posts: 32 Location: Madrid, Spain
Posted: Thu Dec 03, 2009 10:27 am Post subject: |
Josema, como ves, también estoy en todos los sitios.
Josema, you can see that i am in all the bimota´s places. _________________
