fish
Posted: Sat Aug 25, 2012 1:44 pm Post subject: yb11 carb bowl |
hi im looking for a yb11 fuel bowl 38 ml vacume mikuni,s cheers craig _________________ DB1-DB2SR-DB2EF-DB3-DB4 Db10 YB6-yb7_yb10-2xyb11-SB5,2xSB6-kb3-yb5-MILLE MIKEHAILWOOD HARRIS MAGMAN2-TRIUMPH T140-RG500x2-KAWA Z900-SUZUKI GSX1100-DUCATI 900SS- 750 sport ducati DUCATI F1 750- 851 tri colour-500sl-1996 Trumph datona . Vee two alchemy |
Posted: Sat Aug 25, 2012 4:56 pm Post subject: |
Aren't they the same as Yamaha 1000cc Thunderace? Thats where the engine came from, and pretty sure Bimota only changed the end can and front exhaust system from standard, and airbox. Thus Yamaha Dealer or Ebay, should be cheap as only searvhing for Yamaha Parts |
fish
Posted: Sun Aug 26, 2012 11:41 am Post subject: |
yep thats right but yamaha dont list as a separate part to carbys and have tried to source through find a part in aust with no luck yet. _________________ DB1-DB2SR-DB2EF-DB3-DB4 Db10 YB6-yb7_yb10-2xyb11-SB5,2xSB6-kb3-yb5-MILLE MIKEHAILWOOD HARRIS MAGMAN2-TRIUMPH T140-RG500x2-KAWA Z900-SUZUKI GSX1100-DUCATI 900SS- 750 sport ducati DUCATI F1 750- 851 tri colour-500sl-1996 Trumph datona . Vee two alchemy |
![](images/avatars/21144074044f32e652d46bc.jpg)
Posted: Sun Aug 26, 2012 1:30 pm Post subject: |
Just buy a secondhand set of carbs off the bay ... the float bould is probably the same as the YZF750 too. _________________ Don't read everything you believe |
