Sb8r new arrival
Goto page 1, 2, 3, 4  Next
waggy
PostPosted: Sun Jun 10, 2012 9:40 pm    Post subject: Sb8r new arrival Reply with quote
Hi all, just received an sb8r, it's in great condition and well looked after by previous owner. Will get it on the bench and remove the bodywork etc and give it a good going over. Any of you sb8r owners any wise words on things to look out for on this particular model and any useful modifications. It has a power commander fitted, and it starts and idles well, previous owner stated that softer fork springs have been fitted along with an uprated chain and sprocket set.
Any help greatly appreciated.
akito-man
PostPosted: Sun Jun 10, 2012 11:46 pm    Post subject: Reply with quote
What you need to know? Dont just go stripping it down mate- ill let you know, ive just sat here writing down the sequence on my phone and it was that long the fkn thing logged me out and lost my reply, before i could post! Wank iphone!
Ill get on comp and poke summit up for you the morn after hosp appoint mate!
wot you got ?...me..well--
akito-man
PostPosted: Sun Jun 10, 2012 11:48 pm    Post subject: Reply with quote
By the way- hi mate, nice bike, seen her before, welcome to bim8's, have you ridden her yet?
PostPosted: Mon Jun 11, 2012 3:19 am    Post subject: Reply with quote
Nice sb8r mate... nice tesi too Shocked
waggy
PostPosted: Mon Jun 11, 2012 3:45 pm    Post subject: Reply with quote
Been there with the smart phone, bleeding things drive me nuts at times.
The bike is pretty tight, only issue have found is one indicator not working.
The bike was the one that was recently on ebay.
Am just removing all the body work, to check everything Ok, change out all fluids, check valve clearances, bearings etc. looks to have a fuel quick disconnect fitting next to idle screw, which I assume is not standard. Will try post some photo's as i go along.
PostPosted: Mon Jun 11, 2012 4:03 pm    Post subject: Reply with quote
Welcome aboard Waggy!
waggy
PostPosted: Mon Jun 11, 2012 5:38 pm    Post subject: Reply with quote
Thanks pompey, glad to be aboard.
PostPosted: Mon Jun 11, 2012 5:40 pm    Post subject: Reply with quote
Ah ha.........
the sneaky fecker who outbid me on gaybay Laughing
Welcome aboard and thanks for saving me from a bike I couldn't afford Wink
waggy
PostPosted: Mon Jun 11, 2012 6:04 pm    Post subject: Reply with quote
Sorry about that oily, then again you're the sneaky fecker that made me pay more than i needed too Laughing
PostPosted: Mon Jun 11, 2012 6:18 pm    Post subject: Reply with quote
true........but less of the "sneaky"....I advertised the fact I was bidding Wink
PostPosted: Mon Jun 11, 2012 6:27 pm    Post subject: Reply with quote
Waggy, you'll fit in fine!
akito-man
PostPosted: Tue Jun 12, 2012 12:19 am    Post subject: Reply with quote
Elec connector on right by shock res- make sure you dissconect, rear number plate holder / indicators off first- then onto exhaust cans ,Cans can come off without taking bracket to hump off, first remove carbon heatguards on pipes, then springs from downpipes in swingarm space then pipes after seperating from each other first( joining bolt)in between two pipes- should wiggle then pull up gently!Smile
akito-man
PostPosted: Tue Jun 12, 2012 12:22 am    Post subject: Reply with quote
Loosen bolt at seat for rubber vibe wedge to tank, rear end bolts 3 either side counter sunk- tank ones first- then 2 frame each side- rear coms back and over rear brake res- be carefull!
akito-man
PostPosted: Tue Jun 12, 2012 12:28 am    Post subject: Reply with quote
Then tank- first take off top fairing- leave on mirrors and screen if u want, pull forward and off air lufts( carbon), check first for extra wires for extras !
Tank has one bolt by headstock- long one with cap, connector and quick release fuel line joint present on left! Now tank can lift back and up/ off. Be aware of all wires and relays , dont knock or move em about!, this now allows you to rear plug access! Front plug access can be got with care via battery box through forks etc!
waggy
PostPosted: Tue Jun 12, 2012 8:46 am    Post subject: Reply with quote
many thanks akito, much appreciated. Have guests on holiday this week, so probably be banned from the man cave this week, but will post some pics when i get the chance.
Page 1 of 4
